Show us your engine
- Contacteer:
Thought I would show you my 1915 cc engine.
it has a lot of goodies in it..
AS 41 crankcase, fullflow drilled.
CB 69mm counterweight crank, 8-dowel
Original flywheel, drilled for 8 dowels
Kennedy Stage 1 preassure plate
Power pulley in alu.
Orginal connecting rods
Cima / Mahle forged pistons and cylinders 94x69
Engle W125 camshaft
Scat lifters
CB 3/8" chromoly pushrods
Orginal rockers with swivel feet
Original, but ported heads with high performance single springs
Bosch 009 distributor
Bosch coil
Scat doghouse tinware
55 amp AC generator
Schadeck 26mm oilpump
Gene Berg cast Iron oilpumplid
Dual Weber 40 IDF , 52 idle, 140 main
1 1/2" merged header, ceramic coated
Overall it has been a build on a tight budget, and came out at about €3000
Now to the pictures:
Link to the car on the Dyno: http://www.youtube.com/watch?v=0tnLbLVwVQU
This Dyno showed 260 hp on a 300hp car, but gave me a respectable 94,5bhp@4600rpm, 165Nm@2900rpm (which should evaluate to ~105 bhp)
The exhaust actually is very silent and all you hear while driving is the growling from the webers...
Anyway, this thing is insane to drive!
Engle W125 camshaft
Scat lifters
Bosch coil
55 amp AC generator
Forumadministrator at www.beachbuggy.se
